Here's my current build:
Total: $860.91
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
Processor: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=AMD+Phenom%E2%84%A2II+X4+955+Black+Edition+Quad-Core+CPU+w&x=0&y=0
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
2x (for 8 gb) G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Graphics: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102918
SAPPHIRE 100311-2SR Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Bluray Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136232
LG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model UH12LS28 OEM LightScribe Support - OEM
Couple questions. Am I going to be fine for cooling with the fans for the gpu and cpu and the 3 case fans?
and I have had it suggested that I go for a HD 6950 instead, should I, from a purely performance standpoint?
If I did go for the HD 6950 which of these should I get:
Sapphire - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102945
HIS IceQ X - http://www.newegg.com/Product/Product.aspx?Item=N82E16814161372
Appreciate any advice or suggestions!
Total: $860.91
