Will this build work?
Hi everyone im doing my first build and i was wondering about these components.
i5 2500k
gigabyte gtx 560 ti soc sli/xfx radeon hd 6950 crossfire (need help on which to buy)
asus p8z68 v-pro motherboard
12gb ram
coolermaster HAF 932 (will this case fit my components?)
also need to know what psu i would need
3 answers Last reply
More about will build work
  1. CPU: the performance choice these days
    Mobo: also consider Asrock Z68 Extreme 4 Gen 3
    Ram: get either 2x4GB 1.5V CAS9 1600Mhz or two of the sets.
    Case: Good solid case with great airflow, will fit the components listed
    PSU: 750W PSU will be sufficient. Corsair/XFX/Seasonic/Antec
    GPU: Whichever seems better for you. Performance is roughly the same when you OC the GTX560ti's.
  2. I seem to remember lots of problems with the GTX 560Ti SOC Edition - you might want to look more into this.
    The standard OC edition is fine, but I remember lots of RMA's on the SOC cards even after it was down-clocked from the factory 1GHz to 950MHz.
    RAM - Make sure your looking at DUAL CHANNEL RAM. As rvilkman said, 2x4GB sticks 1600MHz, 1.v5, CL9 - G.Skill and Corsair Vengeance are popular and well recommended choices.
  3. I would get a high quality 750-850w psu and I would get gtx560 ti sli as they are shorter and have less microstuttering in SLI.
Build Components Systems
