Closed Solved
Where does the power switch go on a motherboard?
Where does the power switch go on a motherboard? I got 3 pairs of wires: PW Led, DDD Led and Power Switch.
I got an e-Machine T3302. Please help.
12 answers Last reply Best Answer
More about where power switch motherboard
  1. First of all, you need to know what motherboard you have.
    If you still have your motherboard user's manual (if it even came with the computer), there should be a graphical chart that shows you exactly where all those things go.
    If not, google it. Might be able to find something.
  2. Or if you could take a picture of the motherboard (with as much detail as possible), we might be able to help locate the correct positioning for your front panel I/O headers.
  3. Best answer
    It will vary based on your motherboard, this might help though:
    http://attachments.techguy.org/attachments/154194d1249309082/intel-front-panel-pinout.gif
    Make sure to check your motherboard manual for correct placement.
  4. The mother Board says K8M-800M. I got it powered on but seems like just the fans are running. The CD will not even open now. Maybe I got the wires backwards?
    http://dl.dropbox.com/u/55409132/IMG_20120103_112213.jpg
  5. It appears you don't even have your power switch plugged in.
    Where does it go. I only got 3 pairs of wires as seen in the 3de picture. Am I missing a wire? CD Rom don't open.
    All the lights work, fans are running but CD-ROM don't open. Will it matter if the wires are turned around?
  8. Is this your Mobo? http://www.ebay.com/itm/GATEWAY-EMACHINES-T3393-D6045-T3302-AMD-MOTHERBOARD-NEW-/390288067406
    We need a bettter pic of yours and/or the model number if you can, a bit of hunting threw up http://www.webanswers.com/technology-computers/have-motherboard-k8m-800m-on-emachine-t3302-need-front-panel-jumper-settings-56712a and if the manual on that link is yours then you're good,
    also, the pins for the power switch should be marked 'pwr sw' the ones you have there look like the led plugs
    *Edit, the cd drive is plugged in and connected with the data cable properly I asssume?
    Moto
  9. Lights are on, fans are spinning, CD open now but don't here a beep when I restart computer.
    Computer worked fine till the front cables came off and with all the help the cables are back. Now it will not beep or boot up at all
  10. Assuming you now know what goes where pin-wise, run through this to see if you have missed anything out
    http://www.tomshardware.co.uk/forum/288241-13-read-posting-buyer-guides-troubleshooting
    Sections three and four are most applicable obviously
    Moto
    Moto
  11. I want to that you all for helping me with this. I got it working. The problem was the power switch on the front cover, the wires was loose.
  12. Best answer selected by Jahluka.
CPUs Motherboards Power Switch LED Monitor
