Will these two different RAM brands work together? Help!
Hello all. I'm buying a Motherboard that's coming with free RAM. I had bought RAM already and was wondering if these two will work together without issue. Below is the MoBo that I'm ordering and the two RAM brands and specifications that I'm wondering about.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837 - Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144614 - Included RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345 - RAM I have already
What I'd like to know is that even though the Speed is the same between these two, will the Timing make any bit of difference?
I believe the Timing for the one that's included is 9-9-9-24 and the one I have is 9-9-9-28
Thanks so much for the help.
1 answer Last reply
More about will brands work together help
  1. Someone, please? :|
Memory RAM Motherboards Product
