Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > 3 monitor setup (Please help)
Forum Graphics & Displays : Graphics Cards 3 monitor setup (Please help)
I just bought a Gateway DX4860 - UB21P. It's an Intel i5 processor, Windows 7, w/ a 300w power supply, has a built in Intel HD Graphics 2000. I have 3 monitors with VGA cables (two Asus VH197 LED monitors and 1 AOC, dont know model number). Unfortunitly I only have 1 PCI Express 2.0 slot on my mobo. Does anyone know what kind of graphics card I need to run 3 monitors? I'm only doing business programs like Quickbooks, this isn't for gaming. I noticed that most graphics cards have DVI slots and I'm not sure if the 2 Asus monitors can use DVI cables. If I need adaptors I need to know if I need passive[b] or [b]active.[/b][/b]
I've tried ATI Radeon HD 5450 that has DVI, VGA, and Disploy port but I could not get all three monitors to work, only 2 at a time.
On my previous pc I had an Intel PIII w/ Windows XP, a built in graphics chip and I used an AGP graphics card from Galaxy with 2 VGA ports. I was able to use the built in graphics chip and the video card at the same time with all 3 monitors and it worked fine.
Reply to kman1981
for eyefinity, 2 card needs to be conneected via DVI and the middle 3rd must be with display port.
Question: what are u gonna use it for ?
------------------------------ True Malaysia
Malaysian Fact
LittleGreg:Core i5-2500,8GB ddr3,MSI P67A-C45,Sapphire HD6950 1GB,3TB Total HDD,Xigmatek NRP-PC602
Lappy: Athlonx2QL62, 4GB ddr2, HD 3200 IGP
Reply to greghome
This is only being used for business purposes, examples: quickbooks, web surfing, Excel files, word programs, etc. I don't plan on doing any high games or designing.
When I bought the ATI Radeon 5450, I was told that you can't convert an analog signal to digital so the display port wouldn't work for me. I did look up the ASUS monitors that I have and I can not run DVI cables for them so I'm obviously going to have to use adaptors. Unless there is a video card that has 3 VGA ports for triple monitor support or a video card that is compatable to work with the Intel HD Graphics 2000 and has 2 VGA ports.
Reply to kman1981
here you go kman
http://www.newegg.com/Product/Prod [...] 6814102938
this card will do 3 monitors really well for your apps....and here is a displayport adapter
http://www.newegg.com/Product/Prod [...] 6814999030
after hooking all this up......activate them in your control panel using the "extend this desktop" option in the display options......
good luck
------------------------------ i5 2500K@4.8GHz/Asus P8P67wsRevo/ 2xasus 6970 in cfx/ 8g mushkin 2133MHz /CorsairH60/ 2x Crucial M4's in RAID0 128gb/ 1000w nzxt/ http://i1084.photobucket.com/album [...] rx/153.jpg http://i1084.photobucket.com/album [...] rx/148.jpg
Reply to badtaylorx
Dude, display port to DVI ? for the 3rd middle monitor,
DVI-VGA for the other 2 ?
BTW, does those Asus have DVI ? cant find them info on that on google
Malaysian Fact
Reply to greghome
badtaylor: I checked out the video card you posted, I like it but a couple questions. Since the 3 monitors that I have are VGA how would I hook 1 of them up to the display port? When I bought the ATI Radeon 5450 (returned it of course) I used a VGA to DVI adaptor and piggy backed that into the DVI to Active Display port adaptor and It didnt work. Is it possible to hook up a monitor w/ a VGA connection into a display port? If it is possible then I would need an adaptor for each port on that card and by using an adaptor for each port could it still operate all 3 monitors?
greghome: here is a link for the Asus monitors http://www.asus.com/Display/LCD_Mo [...] ifications or http://www.all-monitors.com/monito [...] sus_vh197d
From reading the specifications, they are VGA only..... None of the monitors that I have are DVI or Display Port. They are VGA only. I know theres a VGA to DVI adaptor but what about the display port adaptor?
If it helps the link below is the PC that I bought. In the specs under Available Expansion slots shows 2 PCI Express x1, 1 PCI Express x16. I was pretty upset when I realized that theres only 1 PCI Express x16 slot on the mobo. I've seen video cards for PCI Express x1 but the variety is extremely slim. There are only 5 on Newegg.com and I dont know if 2 or 3 can work at the same time.
http://www.bestbuy.com/site/Gatewa [...] Id=2632043
Message edited by kman1981 on 08-03-2011 at 02:50:19 AM
Reply to kman1981
well, then u'll have to grab a flex card then..........
the 3rd monitor will always have to be digital, so HDMI to VGA is more common than display port to VGA, plus the other 2 can just suck output outta VGA or DVi-VGA.
One more thing: Never buy PCs from best buy, or any stores for that matter.......go ,DIY
Malaysian Fact
Reply to greghome
Whats an average flex card and what makes it different so that would work? I've been out of the PC scene for awhile so I'm a little behind of the new stuff. What kind of adaptors should I use?
Reply to kman1981
Here's the cheapest Flex card.,
Sapphire HD5670 Flex
Almost all AMD DX11 GPU cards can do 3 monitor on one card, but they require the use of the display port output, however since ur monitors are all old stuff, u cant use the display port output, partly because I've never seen or heard of a display port-VGA adapter.
Sapphire Flex cards do not require the above said criteria, Eyefinity can be set up with them by using the HDMI instead of display port, considering HDMI-VGA should technically be easier to find
Malaysian Fact
Reply to greghome
Here's a display port to VGA adaptor:
http://www.newegg.com/Product/Prod [...] 6812340010
Thanks for posting that vid card, that's the one I'll probably get. I'll let ya know how it works out.
Reply to kman1981
I'm surprised they don't have dvi connectors. My 2004 LCD has both dvi and VGA. I've never done this myself but apparently for lower resolution some passive adapters work, but I've never tried sine all my monitors use dvi. Some feedback how it turns Out will be greatly appreciated.
Reply to Supermuncher85
I was surprised that these monitors don't have a DVI port also. Being that they're only a year old and have a 10,000,000:1 contrast ratio.
Reply to kman1981
Hey can i use the Sapphire Flex 5670 With a DVI / VGA and HDMI. I already have the HDMI wires ran thru the wall, and really don't want to untie and re-run wires. I have 3 Monitors i am using for work. Nothing fancy, One display need to what serquirty camera via internet, the other screen will be for emailing, third for internet browsing.
So I goes my question is, Can I use this card for what I need ? and do I need to buy any adapters. I would like to use HDMI and either 2 DVI or 1 DVI/1 VGA thanks
Reply to RichieC10306
Ok so I have the Sapphire Flex 5670 HD installed, but I think I have a problem. I was planning on using both of the DVI ports and the Display Port for my 3 VGA monitors. One of the DVI ports is a DVI-D Dual Link and the other is a DVI-I Dual link. I can plug one monitors into the DVI-I using a DVI to VGA adaptor and another monitor into the Display Port using a Display Port to VGA adaptor, but I can not plug the last VGA monitor into the DVI-D port because DVI-D is Digital only, and thus can not drive an analog (VGA) monitor. I haven't tried a DVI-D to VGA adaptor because all of the reviews (see link below) from people that have tried said it doesn't work. Since my last option is the HDMI port, is there an HDMI to VGA adaptor? I'll post the links below for the adaptors I was looking at using.
Monitor 1 (middle)
Display Port to VGA Adaptor:
http://www.newegg.com/Product/Prod [...] 6812270279
Monitor 2 (left) <--- Monitor and Adaptor in question.
DVI-D to VGA Adaptor:
http://www.newegg.com/Product/Prod [...] 6812119261
Monitor 3 (right)
I used the adaptor that came with the video card. Link below is what it looks like.
DVI-I to VGA Adaptor:
http://www.newegg.com/Product/Prod [...] 6812119041
Information on DVI Connectors:
http://www.datapro.net/techinfo/dvi_info.html#Page03
RichieC - I have read that this video card is capable of running 4 monitors. What kind of connection cables do your 3 monitors have? If your monitors are all VGA then we're in the same boat but if they are DVI, HDMI, and VGA then your ok. If you do have that configuration then I would connect them up by using the HDMI port, DVI port, then purchase the Display Port to VGA Adaptor listed above and your good to go.
Reply to kman1981
I wish I had seen this thread earlier. For non gaming buisiness purposes a Jaton Quad is your best bet for running more than 2 screens on a single card.
http://www.newegg.com/Product/Prod [...] 814139037R
Reply to benski
No, just regular old PCI.
http://www.newegg.com/Product/Prod [...] 6814139055
That one is PCI-E.
I wonder though, is it not possible to use your integrated graphics and the PCI-E card at the same time? Can you enable them both from bios and have the card you got (5670) run 2 monitors and the integrated graphics run the other one?
Reply to benski
I've actually tried that when I bought a ATI Radeon 5450. When I checked the bios I found that there isn't an option to enable it.
Reply to kman1981
It works with some, while not with others. On my AMD board for exmaple I can use my integrated with a dedicated GPU. Not much need for it though since I already own an eyefinity ready card. So point being, it will depend on your motherboard.
kman1981 wrote :
I just bought a Gateway DX4860 - UB21P...
Hi kman- assuming you got your three monitor setup working, can you provide the parts used and the setup? I have the same computer currently using two DELL VGA monitors and I would LOVE to add a third.
I too use this machine for work (not gaming).
So, what did you end up doing? Which card? Which cables? What settings.
I would like to mirror your set up :)
Thanks,
easyA314
Reply to easyA314
Thanks,
easyA314
I've actually been MIA from the whole setup for a while because it's my brothers pc that I was setting up and he ran out of money. Anyway I haven't set up the third monitor yet but it is possible and I'll tell you how. The only problem I ran into is that there aren't any HDMI to VGA adapters (just converters and they aren't cheap), BUT I did find several solutions and I posted the link below under Monitor 2. The settings are easy to configure since the software that came with the vid card is pretty user friendly.
I still have the Sapphire Flex 5670 HD installed and used:
Monitor 1 (middle)
Display Port to VGA Adapter:
Monitor 2 (left) <---below is a link that show's 4 adapters that'll probably work, but I haven't tested one yet. I plan on picking up one of those and setting it up this week. I'll post the results.
http://dl.dropbox.com/u/52342203/adaptors.jpg
Monitor 3 (right)
I used the adapter that came with the video card. Link below is what it looks like.
Reply to kman1981
If you haven't purchased a 3rd monitor yet, then I highly recommend getting a monitor that uses a DVI connection since most vid cards are using that now.
Reply to kman1981
Awesome, thanks kman...I will review the above post today :)
And I have not procured my third monitor.
I currently have two DELL 2007FP 20" and a NVIDIA GeForce GT 520 Display Adapter.
The monitors I have are Dellâ„¢ UltraSharpâ„¢ 2007FP 20.1-inch Flat Panel LCD Monitor - Dell site says "digital (DVI-D) capabilities" and Video Input = DVI which I connect both to a single Y-cable into my video card.
*** CORRECTION *** That was my old Dell system setup...with my Gateway, I have one monitor connected via DVI (white) and the other VGA (blue).
What would you recommend...and can I have a larger middle monitor with the two 20"'s on the sides? Or is it a distraction? I am sure another 20"-er is fine, but perhaps a larger central viewing area would be nice...as long as it is not a distraction moving from one to the other.
Thanks for your advice...it is much appreciated.
easyA
Reply to easyA314
You can have a larger monitor in the middle. My middle monitor is slightly larger with a normal display, my side monitors are slightly smaller (by an inch) and they have a widescreen display.
Does your current set up expand the desktop view or are you just splitting the video so you have the same thing on both monitors?
Reply to kman1981
I have the desktop expanded :)
Reply to easyA314
There are 1464 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 3 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
