J johnnyb_27 Distinguished Mar 22, 2011 41 0 18,530 Jan 3, 2012 #1 Will the fans work at there maxium rpm when they are hooked up to a four pin connected to a power supply?
Solution wiinippongamer Jan 3, 2012 Yes. You'd have to connect them to your mobo 3-pin or 4-pin and adjust from the BIOS or get a fan controller if you don't want that.
wiinippongamer Distinguished Sep 9, 2009 1,927 0 20,160 Jan 3, 2012 Solution #2 Yes. You'd have to connect them to your mobo 3-pin or 4-pin and adjust from the BIOS or get a fan controller if you don't want that. Upvote 0 Downvote Solution
J johnnyb_27 Distinguished Mar 22, 2011 41 0 18,530 Jan 3, 2012 #4 Best answer selected by johnnyb_27. Upvote 0 Downvote
