Front panel audio help
Last response: in Systems
I need help with my front panel audio connectors. My mobo is Z68 gigabyte XP-U3DP. I have read the manual concerning the audio connectors but followed the instructions and my front panel headphone still doesn't work.
I have no idea what my case is since there is no model # inside or outside the case since i'm reusing it from 2005.
My case has these front panel audio connectors
R-Out/R-Ret (1 wire 2 pin holes)
L-Out/L-Ret (1 wire 2 pin holes)
Mic In/Mic Vcc (1 wire 2 pin holes)
Ground (1 wire 1 pin hole)
What does NC mean in the motherboard manual??
http://download.gigabyte.us/FileList/Manual/mb_manual_g...
page 27
More about : front panel audio
Cases from 2005 may not support front HD Audio, you will have to follow the pin guide for AC-97. Once you are done with that, go into bios and see if you can change the front audio from HDAudio to AC97.
NC= No Connection, but also plug in the L-Ret to pin 10 and R-Ret to pin 6.
L-Out into pin 9 and L-Ret to pin 10
R-Out: pin 5 and R-Ret: pin 6
Go to your sound card control panel and disable front panel detection.
Can you set your front audio from HDAudio to AC97 in the bios?
I dont have a sound card. But the front panel detection is disabled. And no I have no option for changing front audio in bios. Only thing thats there is Azalia Codec (Have no idea what that is)
Ask the community
