Ok, i got two questions about my heafsink fan its a Thermaltake SpinQ VT - i know its not the best on out there but i like it mainly because of aesthetics reasons but im pretty sure it still does it job to cool my procie.
1.) The speed aint moving. Its frozen at 17rpm, there is a manual switch/knob thingy attached to the HSF but my casing is closed so i really cant toggle it every now and then to adjust to my temps. Yes smart setting is off in the bios which makes in run 100% all the time which is DOESNT since max rpm on it was 19 i tried. My temps arent really hot, i got 60 Celcius on package and the rest are around 55-59 Celciums - is that warm or still ok? so maybe this is the reason why the RPM does not increase.
2.) Is there a software Aside from speedfan that might adjust the fan speeds? that software does not seem to work for me even at installation i get problems and i dont seem to know how to use it very well sorry
thanks a million.
Specs
Intel i5-2400
Gigabyte h61m-usb3-b3
Gigabyte Gtx 560 ti OC
G.Skill ripjaws 8GB
1TB hitachi
320 WD
SpinQ VT
Hec cougar 700w
thanks a million.
Specs
Intel i5-2400
G.Skill ripjaws 8GB
1TB hitachi
320 WD
SpinQ VT
Hec cougar 700w
