Hello everyone, long time reader here but first time poster.
So I currently have the following:
Monitor - Asus 22.3 inch 1080p monitor
HD - 2 300gb. seagate baracuda 7200rpm 3gb/s
CD/DVD - Just a standard $20.00 drive it's r/rw drive
CASE - Corsair 400r
OS - Windows 7 HP 64bit
PSU - Corsair CS 700watt 80 bronze
So I have recently bought the monitor case and os. I also have a 21 inch acer monitor but I thought since it didn't have the option to use 1080p resolution it was time for a upgrade. I will be ordering parts this Friday and have a $600.00 budge to do so.
Here is what I'm needing CPU, RAM, MB, GC (video card). So I have looked and researched to my hearts content but could use some advice from the community. I'm hoping to use this system for Elder Scrolls: Skyrim, SW:The Old Republic and possibly some other newer games in the future.
My questions are not only what kinda parts do you all recommend but I'm wondering if I should just go a AMD quad core route and save some money or go with something like a i52500k. Is the overclocking on 2500k hard to do? If so I'll probably just go with like a i5-2400 instead. Also what kinda motherboard would you recommend? I'm not a hardcore overclocker but if it's fairly easy then I'll be willing to give it a try. With RAM I'm not really interested in overclocking it but will want at least 1600mhz. What's the difference between like corasair domintor and corsair whatever other name they have? I notice they have a lot of similar ram kits but only differnce I can tell are there fancy names at the end of them. When it comes to video cards I have no idea what I should be looking for. I'm currently using 2 8800gts cards and there hot/loud and are fairly old now.
I'm also thinking that an SSD would be good for a MMORPG or so I'm told. People have said that games with lots of loading screens while your gaming would benefit being put on a SSD drive. I could care less if windows takes 45 seconds to load vs. 25 seconds with a ssd. Looking for raw gaming performacne. Basically best bang for the buck.
I orginally bought a q6600 which I'm running now but since it's running on a old chipset I'll need this upgrade. I really appreciate everyones help in advance. I hope I didn't leave anything out that might help you with helping me. Thanks again.
CASE - Corsair 400r
