Solved
New Build Help; multitasking/multimedia/home workstation
Hey all, long time reader first time posting. I'm building a new comp and would appreciate the help. This is my 4th build but its been a while since my last, any advice is appreciated.
Main Use: multitasking, multimedia, home workstation (would like some future proofing)
Budget is $700-900. No rush on build date but would prefer within the month
Parts Not Required: Keyboard, Monitor, Mouse, have 2 DVD RW drives from my old system
Preferred site: NewEgg or Amazon but open to anything
1} Motherboard: Unsure, open to suggestions...
2} Processor: Intel i5 2500k
3} Memory (RAM): Corsair Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9)
OR should I get:
G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9Q-16GBRL http://www.newegg.com/Product/Product.aspx?Item=N82E16820231312&nm_mc=EMC-IGNEFL100411&cm_mmc=EMC-IGNEFL100411-_-EMC-100411-Index-_-DesktopMemory-_-20231312-L013A
4} Graphic Card: SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express (May do some very basic gaming)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102874
5} Computer Case: Can't decide between the following: Antec 300, Cooler Master HAF 912, Antec 900 or Cooler Master Storm Scout. Would like to save some $$$ here if not giving up much quality.
6} Power Supply Unit: Corsair TX650w vs PC Power and Cooling Silencer Mk II PPCMK2S650 650W vs Cooler Master M600 vs OCZ ZS750W
7} Hard Disk Drive: Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
8} OS: Windows 7 Home Premium
9) CPU Cooler: Do I definitely need one? Not sure I'll be overclocking anytime soon
Thanks in advance for any help!
11 answers Last reply Best Answer
More about build help multitasking multimedia home workstation
  1. Best answer
    In the world of Sandy Bridge motherboards, Z68 is what you want. It comes with onboard video which would be plenty if you don't plan on gaming. Since you're not gaming (at least not heavily), you can basically go for the bargain basement Z68 boards without noticing any difference. The only thing you'll need to be concerned with is the connections in the port cluster. Some people NEED firewire or PS/2 ports, and if you have any particular necessities there, you'll have to find something that will cater to that.
    ASRock makes a good $110 Z68 board.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157251
    You should be able to find a case for under $50 without any problems. The Storm Scout has the advantage of USB 3.0 on the front, which is nice. My favorite case for about $50 is the Rosewill Challenger and I have a cheap Zalman that I like a lot (Zalman makes very quiet cases if that's something you're concerned with).
    Today's Shell Shocker on newegg is exactly what you want for RAM. 2x4GB, 1600mhz, 1.5V, cas latency 9 for $40. To get that deal you have to buy TODAY (october 4).
    http://www.newegg.com/Special/ShellShocker.aspx?cm_sp=ShellShocker-_-20-231-416-_-10042011_2
    16GB of RAM is far too much for your stated usage.
    If you're not overclocking then skip the CPU cooler unless you're concerned with noise. The i5 stock fans can get a little loud and a $30 aftermarket fan will be significantly cooler. You can get away with trying out the stock fan and seeing if it's too loud and then upgrading, but to do that you will likely have to take the motherboard back out of the case. In terms of cooling, you will not need an aftermarket cooler.
    When you buy Windows 7, save yourself some money with the OEM version.
    If it's worth the $5, newegg has a sale on the Samsung Spinpoint F3 until Thursday. It's a very similar drive from Samsung.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
    Your power supply is WAY too big. You can get away with a 350W PSU with no problem.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371003
    If you plan on upgrading to a real video card at some point then you'll need more power, but for the system and card that you stated the Antec Basiq is fine.
  2. Seeing as though youre not too bothered about overclocking i would go for something like this:
    i5-2400
    8GB G.Skill Ripjaws X
    ASRock H61M/U3S3
    HIS Radeon HD 5570 1GB (Passive cooled)
    Antec EarthWatts 430W
    Samsung Spinpoint F3 1TB
    Crucial M4 64GB
    Fractal Design Define Mini OR Coolermaster Silencio
    That should be nice and fast as well as being super quiet, adds up to about $800.
    Also if you don't want the SSD you could take it out and change the CPU to an i7-2600.
  3. Thanks a lot for the messages guys. The ASRock z68 MB looks great and appears to be somewhat future proof (i luckily don't have any firewire or PS/2 port needs). I think i'll go for that one.
    About the memory, I saw the deal on today's Shell Shocker but how does that ram compare to the Ripjaw X series or the Corsair Vengance? I don't mind spending 15-20 bucks more if its going to be noticably better ram, maybe these: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231430 . I've had great expeirence with Corsair in the past, never used G skill but have heard good things. What do you guys think?
    Regarding the HD, I don't mind spending a bit more for the Samsung Spinpoint, are they superior to Seagate or WD HD's? New Egg has a $10 discount on the Samsung right now so it'll actually be cheaper: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=e2zoerz1ja6a
    About the smaller PS, i'm nervous about being under powered for possible upgrades later and also with having a cheap PS which may be more likely to fail/higher voltage fluctuations etc. What about the following 2: PC Power and Cooling MK II on sale: http://www.newegg.com/Product/Product.aspx?Item=N82E16817703025 or OCZ ModXPro 500w http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
    Lastly, JMSellars1, I know I said I don't plan to OC but I'd like to have the option of doing so, I heard AZRock's BIOS makes it quite easy to do so I would like to keep the option open. Also, is the HIS Radeon you recommended better than the Sapphire one in my original post?
    Thanks again for the help!!!
  4. I just chose that card because it is has no fan so it would contribute to a very quiet system.
    With the HDD, yes the Samsung Spinpoint F3 is faster than anything else at that price point.
    I'm sure G.Skill Sniper memory is great, no noticeable difference between that and Vengeance i think.
    Remember that just having the option to overclock means you have to spend like an extra $80 on your motherboard and CPU which could be put to better use elsewhere (ie. Very quiet PC and SSD or i7) if you don't mind about overclocking.
    With the PSU, don't consider Antec a cheap brand, theyre up there with the best. That EA-430W PSU is very stable and very quiet with more than enough power to upgrade the graphics or add HDD's etc.
  5. The shell shocker ram is just as good as any other 1600mhz, 1.5V ram. The Samsung and the Seagate drives are basically the same - you won't notice a difference. Antec, Corsair, and Seasonic are the brands you want for a PSU. Getting enough wattage for upgrades makes sense, but go for those three brands.
    If you want the most up to date system for a reasonable price, Z68 is the way to go. H61 and P67 will both work fine with sandy bridge, but H61/H67 is getting outdated for new builds and P67 is more for gamers who plan on overclocking.
  6. One last thing, you should consider the passively cooled video cards. The lower end cards are nice, cost effective solutions for light gaming, but the fans get surprisingly loud. I have a gtx430 and even when I just push it a little bit, the fan is easily the loudest part of my computer.
  7. JMSellars and Danraies, thanks again for the help! Below I have my almost final config if you have any more comments. Most of the stuff I took your suggestions on. Ram I stuck with the Corsair based on my great experience with their products in the past. The PS I also went with Corsair since you guys said its a solid PS company as well.
    1} Motherboard: AsRock Z68 PRO 3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157251
    3} Memory (RAM): Corsair Vengeance 8GB CMZ8GX3M2A1600C9 http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144&Tpk=CMZ8GX3M2A1600C9
    4} Graphic Card: (the HIS recommended by JMSellars is sold out) so I stuck with the SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express (May do some very basic gaming)
    http://www.newegg.com/Product/Prod [...] 6814102874
    5} Computer Case: Still can't decide! I have it down to these finalists, the price of the cheaper ones comes out to the same as the more given the free shipping. Cooler Master CM 690II $88, CM Storm Scout $90, Lian Li Lancool $99, and CM HAF 922. The CM HAF 922 seems to have the best airflow.
    6} Power Supply Unit: What do you guys think of this choice: CORSAIR Builder Series CX500 V2 500W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
    7} Hard Disk Drive: Samsung F3 http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=e2zoerz1ja6a
    9) CPU Cooler: Still up in the air about but as Danraies said I should be fine with stock fan
    Thanks again guys! :)
  8. i'd go haf 922. Corsair is reliable brand, so that psu sounds like a good choice. I'd stick with stock fan, but it's up to you.
  9. It all looks good. Any of those cases are good choices - it's all personal preference with cases. You don't have to worry too much about airflow since you're not using a high-powered graphics card so if you want to go cheaper, you certainly can.
    The PSU will be great.
  10. Best answer selected by thehomez.
  11. Thanks again for the help guys. In the process of picking everything up this week and next :)
New Build Systems Product
