Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > [Solved] New build for BF3/Rage/Skyrim. Help, criticism, critique welcome
Forum Systems : New Build [Solved] New build for BF3/Rage/Skyrim. Help, criticism, critique welcome
Best answer from joshybo7.
Hello there. Im building a new rig specifically for the games above, as well as future titles, and I'd like some feedback. Id like to play these game at high/ultra settings if able within my budget. This is NOT my first build, I had been doing it for years up until about a few years ago due to money, travel, moving etc, and im pretty out of the loop, but any feed back would be appreciated. If you think there are components I can find alternatives to to shave off a few bucks cool, as long as it doesnt sacrifice power. Thanks much.
For: Gaming (battlefield 3, skyrim, rage, etc)
Budget:1000-1300 USD
Parts: Microcenter (all prices are from their website in the last week or two, Ill be picking them up in store)
Parts not needed: monitor, speakers, mouse, keyboard.
Components list:
Case: Nzxt Phantom II - 112.00
Cpu: I5-2500k - 180
Mobo: Gigabyte GA-Z68XP-UD3 LGA 1155 Z68 ATX 155.00
Psu: Corsair Gaming Series 800 Watt High Performance ATX 140.00
HD: Seagate Barracuda 7200.12 500GB 7,200RPM SATA 6.0Gb/s 3.5" 45.00
Optical: not concerned. approximately 20.00
Ram: Patriot Viper Xtreme Series 4GB DDR3-1600 or Patriot Viper II Sector 5 Series Patriot Viper II DDR3-1600 each 50.00
GPU: either 2x GTX 460's 1gb or x2 Ati 6850 1gb. Id prefer 460's however im finding them increasingly difficult to find on the market.
$320.00-340.00
Do you think this is suitable for high settings on the games mentioned, and holdup for some time?
My other alternative would be a single GTX 570 and at a later date, buy a second one. As is theyre roughly 300.00-320.00
Is the dual card set-up better or the single 570. Im looking for instant gratification here. If the single 570 pulls as much weight as X2 460's or 6850'S ill take it.
Otherwise dual cards are what id go for.
Total around 1050.00 w/o cooling, tax and MIR
The other component that im most unsure of, is the heatsink/cpu cooling, I was looking at the Noctua Dh-14,
but it isnt available at microcenter, and i was actually hoping for something more around 50-70 to wrap up the build that i old find in store that is community approved and recommended.
Thoughts?
Reply to Hey_Yo
Also already have OS. Sorry missed that
Reply to Hey_Yo
Are you willing to buy parts from newegg/amazon?
I'll just modify a few parts. The rest can stay the same.
Mobo: asrock extreme3 gen3 $125
Cpu cooler: cm hyper 212 evo $35
Psu: corsair tx850 $130 or Xfx core edition 850w
Gpu: gtx570 (future sli) $300-350
Prices from
Newegg.
Bf3 beta: http://www.geforce.com/Optimize/Gu [...] ance-guide
Message edited by Sky03 on 10-05-2011 at 08:25:09 AM
Reply to Sky03
Yes im definitely willing to snag parts from NE, I most likely still get the mobo in store to get started, I have other components from other pc's that can sit in till the new stuff arrives.
Thanks much for the feedback!
Reply to Hey_Yo
more you miight get from newegg:
8 GB DDR3-1600 is $47.99 there.
http://www.newegg.com/Product/Prod [...] 6820161452
You might also consider the Challenger U3 case ($59.99)
http://www.newegg.com/Product/Prod [...] 6811147060
use some of the savings for a SATA III SSD around $100
http://www.newegg.com/Product/Prod [...] 6820227728
http://www.newegg.com/Product/Prod [...] 6820148441
http://www.newegg.com/Product/Prod [...] 6820227725
Message edited by ScrewySqrl on 10-05-2011 at 04:16:01 PM
------------------------------ We have no wish to offend you, unless you're a twit.
My PC: I5-2400, ASRock H61-VS, Mushkin 4 GB 1333, HD 6850, 2x Seagate 500 GB HDD, Corsair 430W, Rosewill R102 case
HTPC: Phenom I 9650 2.3Ghz, 4 GB DDR2-800, 120gb hdd, HD4850 512MB, Ultra 500W
Reply to ScrewySqrl
The case is a bit smaller than Id like, but i am considering a sata drive. I might just over extend my budget a bit and get one.
Edit:
Awsome thanks for the links ;)
Message edited by Hey_Yo on 10-05-2011 at 04:21:23 PM
Reply to Hey_Yo
cases are subjective. I like Rosewill cases as great deals for the money
Reply to ScrewySqrl
I am curious, are you going to be doing video encoding or anything like that? if not then the motherboard with z68 is overkill, a p67 will work just as well for gaming, it just won't support the integrated gpu on the sandy or the quicksync, just depends on what you use it for although personally i run my 2600k on a p67 as i saved a few dollars on my build avoiding features i would not use. also, i would go the 460's will outperform the 570 if i am not mistaken, although of course getting a single 570 now will future-proof you for sli later on just depends on how immediately you need that boost in performance as opposed to being future-sighted.
------------------------------ intel 2600k oc @ 4.5 GHz, 8 gb corsair vengeance, asus p8p67 pro rev 3.1., corsair h60, evga gtx 580, corsair 600t white edition, corsair ax850, seagate barracuda 500gb
Reply to joshybo7
I'd go with the 570 and SLI another when they're cheaper.
I'm a bit out of the loop on nvidia cards at the moment, however. I only suggest this because a year ago I went with 1x 6970 instead of 2x 6850s and it will not stutter! It's so great :D I got an open-box model for $300 and it works great, so I got lucky and saved ~$60. IIRC the 2x 6850s would slightly outperform 1x 6970, but gaming at 1920x1080 doesn't have any problems whatsoever. Also have no idea how my single 6970 will handle Skyrim and BF3. Sadly, my gaming rig is out of commission during the BF3 beta. :(
Also, I think with the 1155 as opposed to the 1366/2011, it would make more sense to stick with 1 very powerful card and then start filling up those lanes with a second card later, instead of using up it's potential for 2x SLI immediately on cheaper cards.
Reply to spikey_monkey
I will not be, Im going to use mostly for gaming, maybe some music programming, nothing serious on that front however.
Are there some p67's You would recommend? I do need the mobo to be SLI or Xfire capable
Reply to Hey_Yo
http://www.newegg.com/Product/Prod [...] 6813131771
i use that motherboard, it serves my purposes well and overclocks like a champ for gaming, incredibly intuitive uefi bios, my first overclock was using this board and i am at 4.5 GHz, there was a weird double-post, triple-post issue that a lot of reviewers mentioned, although it is related to the BCLK speed which setting it to 103 as opposed to 100 seems to cause and if you set it back to 100 it fixes that issue (perhaps somewhat too in-depth although just something handy to know, if you opt for that board in the end). also i had a good experience with msi previously
Reply to joshybo7
one other thing on Z68s though is they are designed to speed regular hard drive throughput when combined with a SSD , using the SSD for caching.
Reply to ScrewySqrl
Best answer
he is one hundred percent right about that, and i neglected to mention that, just didn't consider it as i do not own an ssd, so thank you for the correction. definitely keep that in mind if you are going to get an ssd anytime near the time of these purchases.
Reply to joshybo7
There are 1475 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 4 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
