Difference between audigy1 n audigy 2 for recording other than sound quality
i want to make a home recording studio in the minimum budget possible.... as both products i mentioned have a lot of price difference, i want to know the difference, if i buy audigy 1, what 'll i miss....? is it so important...?
1 answer Last reply
More about difference audigy1 audigy recording sound quality
  1. I belive teh audigy 2 supports up to EAX4, where the Audigy 1 supports only EAX3, but its been a LONG time since I had to recall the audigy 1 spec sheet...
    That being said, both are obsolete and likely overpriced as a result. I'd recommend either the ASUS Xonar DG or ASUS Xonar DS instead.
Sound Cards Studio Products Components
