New graphics card not working. Need help!
  • Graphics Cards
  • Dell
  • Graphics
August 5, 2011 8:08:07 AM
I have a dell 875 watt psu, When I install the graphics driver my pc restarts right after the the welcome screen. Is it psu causing this problem? The card works fine in another pc, And I can run my pc in diagnostic mode but as soon as I run any program it crashes and restarts. I had a 5870 before and it worked fine, what should I do? I want to make sure its the psu before I buy one.
More about : graphics card working
August 5, 2011 8:15:42 AM
Doesn't sound like a PSU problem.
Have you tried booting in safe-mode, removing the drivers and re-installing them?
What card do you have?
m
l
a b U Graphics card
August 5, 2011 1:45:55 PM
Did you properly uninstall your previous graphics drivers before attempting to install the new card?
m
l
August 5, 2011 7:33:20 PM
I have an Asus Gtx 580 Matrix platinum edition, I have done everything to make sure its not a softwre issue. Tried different drivers reinstalled windows, nothing worked.
m
l
August 5, 2011 8:07:25 PM
Have you tried using your rig with another GPU since this started happening?
What's the continuous wattage on your PSU.
Some say 700+ and give you 400+ continuous.
Especially knowing that it's a stock PSU.
As far as I know Dell doesn't put anything close to 850w continuous supplies in their rigs.
m
l
a c 578 U Graphics card
August 5, 2011 8:12:00 PM
Do you have two 150W 8-pin PCI Express power connectors connected from the power supply unit to the ASUS MATRIX GTX580 Platinum?
Doesn't that 875 Watt Power Supply only have two 75W 6-pin PCI Express power connectors?
m
l
August 5, 2011 8:13:45 PM
It has 4 6pin and 2 2 pin connectrs, the card also came with 2 6 pin to 8 pin connectors.
m
l
August 5, 2011 8:17:20 PM
Its an alienware aurora, My previous card worked without any problems, itwas a HD5870.
m
l
a b U Graphics card
August 5, 2011 8:27:19 PM
First of all, the 6 to 8 pin adapters are useless. They will not increase the amount of current coming out of the 6 pin PSU plug.
Second ( and my usual question on this subject): The 8 pin PCIe power connector has 3 hot wires (same as the 6 pin connector) and 5 ground wires. Will someone please tell me how adding 2 ground wires will miraculously double the current capacity of the three hot wires?
Third: my motherboard manuals say that a 4 pin CPU plug can handle 120 watts. That means a 6 pin connector using the same size wire can handle 180 watts.
If you do not have enough 8 pin PCIe connectors, don't worry about it . Just use the 6 pin connectors, you will be fine.
m
l
August 5, 2011 8:36:22 PM
But does it work in your pc now?
Couldn't find exact specs on your PSU in that rig but saying that it's "multi-gpu approved" it should run your 580 no problem...
There's still a chance it could be something else too.
Have you overclocked anything?
m
l
August 5, 2011 8:43:48 PM
The connectors that came with the card makes 2 6pin connectors 1 8pin.
m
l
August 5, 2011 8:45:29 PM
I sold that card, nothing is overclocked except the graphics card. so what do you suggest I should do?
m
l
August 5, 2011 8:51:07 PM
Don't use the adapters that came with the graphics card.
Just use each of the 6+2 pin PCI-E connectors on the ends of the two PCI-E cable bundles from the wiring harness.
m
l
August 5, 2011 8:54:23 PM
Did you ever confirm if the ASUS MATRIX GTX580 Platinum would boot into Windows Safe Mode?
m
l
August 5, 2011 8:56:16 PM
Yes it boots into safe mode.
m
l
August 5, 2011 9:18:52 PM
So it appears that during Windows device driver load the problem occurs.
Which graphics card driver and version are/were you using? Was it the latest one from NVIDIA's website?
m
l
August 5, 2011 9:22:45 PM
The driver also loads in diagnostic modebut when i change any settings or run dxdiag or open any videos I get a blue screen and the system restarts.
m
l
August 5, 2011 9:26:07 PM
Did you disable the automatic system restart to see what the blue screen message was indicating as the cause?
m
l
August 5, 2011 9:33:56 PM
No.
m
l
August 5, 2011 9:36:11 PM
rakee18 said:
No.
Maybe you should.
m
l
August 5, 2011 10:28:36 PM
Ok so I disabled automatic restart on system failure after that my monitor lost siganl but the system didnt restart.
m
l
August 5, 2011 10:31:40 PM
Are you actually able to make out anything on the blue screen before it disappears? Anything that points to a specific driver for instance?
m
l
August 5, 2011 10:42:27 PM
Ater abling automatic restart the system didnt blue screened, the video just lost signal when i ran dxdiag.
m
l
August 5, 2011 11:05:23 PM
Does the problem happen with OpenGL applications too or only DirectX applications?
m
l
August 5, 2011 11:13:40 PM
I ave not tried any opengl application.
m
l
