9_breaker Distinguished Jul 24, 2011 865 0 19,010 Aug 5, 2011 #1 i need to know how much power 2 radeon 9850 will use in crossfire.
Solution Cygnus x-1 Aug 5, 2011 Get a good quality 750w psu. Your system will be using far less than that, but you don't want to run it maxed out all the time.
Cygnus x-1 Distinguished Jul 28, 2011 901 0 19,060 Aug 5, 2011 Solution #3 Get a good quality 750w psu. Your system will be using far less than that, but you don't want to run it maxed out all the time. Upvote 0 Downvote Solution
9_breaker Distinguished Jul 24, 2011 865 0 19,010 Aug 5, 2011 #4 Best answer selected by 9_Breaker. Upvote 0 Downvote
9_breaker Distinguished Jul 24, 2011 865 0 19,010 Aug 5, 2011 #5 will 600w be under presure Upvote 0 Downvote
Cygnus x-1 Distinguished Jul 28, 2011 901 0 19,060 Aug 5, 2011 #6 You can probably get away with a 650w but make sure you buy from a top notch company. What's your budget and where do you plan on buying from? Upvote 0 Downvote
9_breaker Distinguished Jul 24, 2011 865 0 19,010 Aug 5, 2011 #7 my budget is about $100 for the psu . im buying from pc case gear Upvote 0 Downvote
Cygnus x-1 Distinguished Jul 28, 2011 901 0 19,060 Aug 5, 2011 #8 pc case gear? Do you have a link? Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Aug 5, 2011 #9 This topic has been closed by Mousemonkey Upvote 0 Downvote
