Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > CM Storm Trooper Fan Controller Problem
Forum CPU & Components : Power Supplies, Cases & Mods CM Storm Trooper Fan Controller Problem
I just finished a new build in the CM trooper case. During the build and testing, the fan controller was working, as far as I could tell, fine. Now, the whole fan control interface seems to be dead. The lights and speakers fail to work. Is there something I am unaware of that I have done to deactivate the controller? If not, do you have any ideas on how to fix it?
Also,
i7-2600k
p8z68 vpro gen 3
AX850 PSU
Reply to raffiy
Is it receiving power at all? Did you check all your motherboard connections?
Message edited by Engima on 01-06-2012 at 07:04:42 PM
------------------------------ AMD PII X4 965BE : MA770T-UD3 : Radeon HD 6850 : Corsair TX650W : Ripjaws 2x4GB 1333 : Lexa S : Hyper 212 Plus
Reply to Engima
Well, the problem seems to have gone away. I left the system alone for about 2 hours. When I turned it back on, the fan controller was functional.
Reply to raffiy
There are 1971 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 7 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
