Solved
Problems with my RAM
So I finished my new build and got it running and everything. I just got one problem.
When I tried putting my two 4gb 1333 mhz Kingston DIMMs, the computer wouldn't get past POST and the RAM red LED was on. If I only put 1 DIMM it turns on and runs perfectly. Is their anything I may do about this?
My motherboard is a Maximus Gene IV Z and, according to the manual, it doesn't seem to support 2x 4gb 1333mhz Kingston, but this just sounds odds to me! Why wouldn't it support 1.5v 4gb DIMMS? Do I have to buy new ram or, as I mentioned before, is their anything I may do about this?
3 answers Last reply Best Answer
More about problems
  1. Motherboards are designed to support a certain maximum capacity and type of RAM. If you deviate from this on the higher side, it will not work.
    You need to go back to the manual and buy the maximum RAM that the motherboard will accept. Pay attention to the type and the RAM frequency.
  2. Best answer
    I had a similar issue. I used this:
    http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems
    Also very helpful for new builds:
    http://www.tomshardware.com/forum/262730-31-breadboarding
    Credit goes to the thread starters, not me.
  3. Best answer selected by cbk12.
New Build RAM Systems
