I just added three Cougar Vortex 120mm PWM fans to my case, the Corsair 600t SE. Two of the cougars are being use as exhausts on top with my H100 radiator on the inside, so they are pulling. Temps are doing fine, if not, they dropped a little from the stock Corsair fans. As for the noise, they are GONE! With music/game sound on I cannot hear my system at all. What sucks though is that the grill on top of the 600t makes the Cougars sound "louder" than they really should be, but since it is barely audible it does not bother me much. As for the third Vortex, it is on the back as my exhaust fan. Loving the look of it.
As for the Cooler Master Megaflow 200mm fan, I do not know if I received a bad one or not, but the stock 600t, the 1000 RPM one, moved more air than the Megaflow does? Putting my hand on the outside grill, I can feel less air, and putting my hand on the inside right by the Megaflow I can tell the difference as well. So, I do not get why the Megaflow has more CFM?
What is confusing me most is that the inside of my case has more airflow now though... I do not know if it is from the Vortex fans or the Megaflow fan. I can feel "some" air around my rear Vortex fan so I know some of it is from there. I just get the feeling that the Megaflow is hindering my airflow now... I don't really feel like taking it out and putting the stock fan back in to test to see which one it is, but I think I have to resort to that.
Just wanted to see what you guys opinions and takes are about this. Also, if you guys think I should change my airflow in any way let me know. Such as, should I use the top two Vortex as intake instead of exhaust, or if I should use the rear Vortex as an intake instead. Let me know!
