Any of these parts not belong with the rest?
This is my first build so I figured I'd see if these parts make sense. I'm using it for coding mostly, and a little bit of gaming. I was told not to be cheap about the PSU and I want it to be able to handle anything I add on later, but is this one totally overkill? Also does anyone have thoughts on whether I should wait until Zambezi comes out before I buy the Phenom, in case there are price drops? I also don't have a case picked out yet, so I'm taking comments on that too.
Phenom II X4 955
GIGABYTE GA-970A-UD3 Motherboard
MSI R6850 Cyclone PE Radeon HD 6850
Team Elite 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
PC Power and Cooling Silencer 910W
Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive
5 answers Last reply
More about parts belong rest
  1. Fill this up and help us help you :)
    http://www.tomshardware.com/forum/261222-31-build-advice
    Btw, when the person told you not to be cheap on the PSU, it meant that you should buy a quality brand PSU:). Your psu is overkill for what you are planning.
  2. Since you don't have a Case and Optical drive yet
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.743728
    get this, it's a pretty good case and with the combo you save $10 bucks.
    Get this, CPU + GPU combo. Same price but better GPU than you have now.
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.748583
    Get this PSU + HDD since you don't have one
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.743513
    If you already have an HDD, get this PSU + Ram combo, better than yours.
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.745021
  3. Approximate Purchase Date: ASAP
    Budget Range: Definitely under 1000 preferably around 700
    System Usage from Most to Least Important: Mostly coding, some gaming, general internet stuff
    Parts Not Required: Have the keyboard, mouse, monitor, speakers
    Preferred Website(s) for Parts: I've got a cart filled on newegg, but I'm not opposed to finding better prices elsewhere.
    Country of Origin: USofA
    Overclocking: Would like to give it a try
    SLI or Crossfire: Maybe some day
    Monitor Resolution: 1280 x 1024
    Additional Comments: Mostly looking for something to last me a while that I can upgrade easily.
    Sorry, don't know how I missed the form the first time around.
    Just check the recommendations I already said. :)
    You also need an HDD. Get the first 3 recommendations and post again what you have changed to your build.
  5. for upgradability use 1.5 volt RAM . Future generations of processors are prone to damage from higher voltage RAM
New Build Systems Product
