Solved
First ever gaming rig help!!
Last response: in Systems
Hello,
I am planning on buying a new rig and I'm stuck between a few different specification combos. Now before I tell you the specs let me say what resolution I will be playing on and what I need the rig for.
- I will be playing on 1920x1080 resolution.
- I will be using this rig for playing games for usually long periods of time(4-10 hours
- I want to play the games I will play at maximum or very close to maximum while going no lower then 30-25 fps, which are(Battlefield 3,Metro 2033,World of warcraft,Crysis modded with photorealism mods,Modern warfare 3,Elder scrolls:Skyrim and Star wars the old republic. (I may be alright with turning some settings off on certain games, for example DOF in metro 2033 stuff like that.)
Spec Variations:
Spec combination 1:
PROCESSOR: Intel® Core™ i7-2600K (8MB Cache) Overclocked Turbo Boost to 3.9GHz
OPERATING SYSTEM: Genuine Windows® 7 Home Premium, 64Bit, English
CHASSIS COLOR: Matte Stealth Black Chassis with 875W Multi-GPU Approved Power Supply
MEMORY: 8GB Dual Channel DDR3 at 1333MHz
GRAPHICS CARD: Dual 1GB GDDR5 AMD Radeon™ HD 6870 In Crossfire
HARD DRIVE: 1TB SATA 3Gb/s (7,200RPM) 32MB Cache
SOUND CARD: Integrated 7.1 Channel Audio
OPTICAL DRIVE: Single Drive: 24X CD/DVD burner (DVD+/-RW) w/double layer write capability
Spec combination 2:
CHASSIS COLOR: Black Chassis with 875W Multi-GPU Approved Power Supply
GRAPHICS CARD: Single 2GB GDDR5 AMD Radeon™ HD 6950
Spec combination 3:
PROCESSOR Intel® Core™ i5-2300 (6MB Cache) Overclocked Turbo Boost to 3.3GHz
OPERATING SYSTEM Genuine Windows® 7 Home Premium, 64Bit, English
MEMORY: 4GB Dual Channel DDR3 at 1333MHz
GRAPHICS CARD: Dual 2GB GDDR5 AMD Radeon™ HD 6950 In crossfire.
Appreciate any advice on which one to choose, thanks!
More about : gaming rig
Yes they are pre assembled as I can't and wont build one on my own :p  I know it's a lot cheaper and all that. I think I may have messed up on the resolution if that makes a difference, I'm at 1920x1080. Not sure if that changes anything but yeah :)  I'm not very tech savvy sorry!
Related ressources
FinneousPJ said:
Assuming system 2 is cheaper than system 1 I'd go with that. The system 3 is nice but you're unlikely to need that much graphics oomph.
hmm if I bought system 2 then I can buy another 6950 down the line right? and then I'm assuming 2 6950s would last me awhile without becoming too obsolete?
Now I wanted 3 the most but someone told me that the cpu would hold the gpus back or something like that?
FinneousPJ said:
Nah that's a powerful CPU but unless you're planning a multi monitor setup you simply don't need two 6950s.
Hmm alright thanks for answering, one last thing if I do get computer number 3 then the cpu for sure wont bog down the gpu even if i'm doing most games at absolute maximum? and number 3 could play most things on max at 1920x1080?
Best solution
From a graphics point of view, option 3 is the strongest, followed closely by option 1, $3 is a distant third.
But, it is not clear to me how many games you will play may need more than two cores.
I think option 1 is the best solution.
But, I think you should seek out more options.
A 2500K based system should cost $100 less, and be just as good from the cpu point of view.
Ask the community
