Cooler master extreme power 600watt psu for gtx 560ti
Last response: in Components
cooler master extreme power 600watt psu for gtx 560ti ??
i have i5 2500k at stock speed,intel dh67cl mobo,4gb ddr3 ram,1 hdd,1 dvd-rw
will it be enough
http://www.coolermaster.com/product.php?product_id=5906...
will it be enough
More about : cooler master extreme power 600watt psu gtx 560ti
will it be enough
actually my friend is also using this psu for 2 years with i3 and 9800gt 1gb and he is fine with it so this psu can do my work???
will it be enough
If you already have that PSU , than the answer is , yes. If you want to buy a new PSU than ill recomend you something better.
That Coolermaster have the efficiency 70+ , all the psu's what ill recomend you are 80+ efficiency.
Related ressources
- Cooler master silent pro m600 watt psu for gtx 560ti or more cards - Forum
- Will Cooler master extreme power plus 600w support MSI GTX 660Ti PE 2G - Forum
- Cooler Master eXtreme Power Plus 500 and GTX 550 Ti - Forum
- Stay away from Cooler Master psu 's. Really ! - Forum
those 3 are not avaliable in my city
what about this
http://store.antec.com/Product/power_supply-earthwatts/...
this is antec 500watt 80+
does it have 2 pci connector?
what about this
what about this
what about this
while my coolermaster is a good supply and I like it, he's right. def avoid that cooler master
www.hardwaresecrets.com/article/Cooler-Master-eXtreme-P...
This is known as one of cooler master's low quality PSUs and there a several threads on it if you do a quick search on the forums here persuading people not to buy them.
http://www.tomshardware.com/forum/300328-28-cooler-mast...
http://www.tomshardware.com/forum/312839-28-cooler-mast...
Stay away from the extreme series IMO, a better quality PSU will ensure no breakdowns.
Just thought i would add that the Antec PSU is much better than that specific cooler master but it won't provide much future proof or room for upgrades down the track, say if you wanted to add another GPU you would also need a PSU upgrade. I would personally spend a bit more money to get a more juicy unit.
both of these will work
( http://store.antec.com/Product/power_supply-earthwatts/...
http://www.coolermaster.com/product.php?product_id=5906... )
you only need a psu with around 35A rating on 12V rail (combined)
i am from karachi,pakistan
see these 2 links of local computer store
my range is 6500rs
now chosse psu for gtx 560ti
http://galaxy.com.pk/powersupply.htm
http://czone.com.pk/html/products_new.htm
my range can go up to 6800rs or upto 7000rs if it is worth
my range is 6500rs
antec has 2 pci connectors??
one another product is cooler master gx 550watt 80+
http://www.coolermaster.com/product.php?product_id=6641
my main question is antec ea500d or cm gx 550watt
bcz both are of same price but gx 550 has 1 pci connector and u sure that antec has 2 pci connectores?
this cm has 2 pci connectors?
and also antec has 2 pci connectors ?
See at galaxy.com.pk, you can see Thermaltake TR2 500W http://www.thermaltakeusa.com/Product.aspx?S=1172&ID=19...
For 6250 pk rupee, it has 36A on +12V rail, I think they should run nicely, but no overclocking though. Also it has two 6-pin needed for GTX 560 ti (one 6 pin one 6+2(8) pin) if you are a bit wondering...
There is no much reviews but I found one: http://thogaming.com/f24/thermaltake-tr2-500w-power-sup...
davcon said:
Buy the Antec Green 500W unit ! The lower end CM units are crappy with one exception the GX450 which isn't enough juice and PCI-E connectors.The only other good unit is the THERMALTAKE TR2 700W-NON MODULAR (TR-700PCEU)= expensive.
What's wrong with GX 550W, which should be sufficient for GTX560Ti if not SLI I believe. This is decent but affordable PSU from CM.
The GX 450 is the only GX series unit i saw that didnt fail a review. There havent been any reviews of the ones built by Enhance but the fact that both the GX 650 and the GX 750 failed reviews for high 3.3V noise, and i believe the GX 550 is based on the same platform leads me to blacklist that unit too. Anyway, i dont trust anything from the GX series after those reviews.
http://hardocp.com/article/2010/11/22/cooler_master_gx_...
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
http://www.hardwaresecrets.com/article/Cooler-Master-GX...
now if i dont buy gx 550 then antec 500watt 80+ and the thermal take 500watt non modular and thermal take 550watt modular are the only option left for my budget and my requirment
which one to buy in these 3
pell380 said:
the antec has 2 pci pins ? i dont know thatExperienced forum members such as hunter315 and myself wouldn't recommend an unsuitable unit.
The EA-500D Green(80 PLUS® Bronze certified) includes 1 x 8(6+2)-pin and 1 x 6-pin PCI-E connectors.
http://www.antec.com/Believe_it/product.php?id=MjIzOA==
Thermaltake TR2 units are also bad choices with the exception of the TR-700PCEU which is out of your price ramge.
Please reread the specification before having doubts
From XFX's website http://xfxforce.com/en-gb/Products/Power-Supply/XFX/Pro... :
Cable Connectors
Fixed FDD: up to 1
Fixed Peripheral: up to 7
Fixed 6+2-pin PCI-E: 2
Fixed 6-pin PCI-E: 2
Fixed ATX12V / EPS12V: one 4+4-pin
Fixed Motherboard Connector: 20+4 Pin
Fixed SATA: up to 8
There you go.
.From XFX's website http://xfxforce.com/en-gb/Products/Power-Supply/XFX/Pro... :
Cable Connectors
Fixed FDD: up to 1
Fixed SATA: up to 8
There you go.
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] reme-power
- Forumhttp://www.tomshardware.com/forum/ [...] power-600w
- ForumCooler Master 600W extreme power plus for GTX 570/560 (470/460) ?
- ForumCooler master GX 550w enough for 560ti ?
- ForumCooler Master Extreme Power Plus 600w
- ForumWill Cooler master extreme power plus 600w support HD 6670 or HD 6750?
- ForumPower supply too small for GEFORCE GTX 560ti ?
- ForumCooler Master RP-650-PCAP 36A. can it handle 560ti ?
- ForumCooler master extreme power plus 460 W
- ForumHow many watts should my PSU have for a gtx 560ti SOC?
- ForumPSU needed for i5 3570k + 7950 vapor x OC + z77 extreme 4
- ForumPentium G630 paired with GTX 650?
- ForumWill a v8 cpu cooler fit a am3+ cpu
- ForumQuiet CPU Cooler that uses stock mounting?
- ForumWhat cooler?
- More resources
Read discussions in other Components categories
it actually suck (at least that what i heard ) you are better off with a corsair,Antec or Seasonic 620-650W PSU it's better to have a larger PSU than what you actually need
