Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > [Solved] Gigabyte 4650 agp problem (no dolby 5.1 using HDMI port)
Forum Graphics & Displays : Graphics Cards [Solved] Gigabyte 4650 agp problem (no dolby 5.1 using HDMI port)
Best answer from jaguarskx.
Gigabyte 4650 AGP problem: (no Dolby 5.1 option using HDMI port). The card is installed and works great but I only get 2 channel Stereo from my HDMI port..(Control panel, Sound, Playback Tab)...is this all the card offers or is something wrong...?? Windows 7 64bit
Reply to bullisb
I don't think that that old card could bitstream Dolby 5.1. I heard that was a feature in newer 5670 cards.
Reply to mister g
Best answer
Yeah, the HD 4670 does not have that capability. You would need a Radeon HD 5xxx or 6xxx series card for that particular feature.
However, there are no AGP versions of those cards. Therefore, if Dolby 5.1 is really important to you, then you will need a new computer that has a PCI-e x16 graphics slot which is pretty much standard nowadays.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Thank you....!! I appreciate the info, just using this old pc as a Media Server. I have a sound card that does the 5.1 but thought it would be nice if the HDMI did it all..... Thanks again.
Reply to bullisb
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1955 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 55 minutes ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
