Memory is stuck at 667mhz at all times
I am using 4 sticks of 1GB GSKill Ripjaws, which due to my system, should be running at 1333.
Rest of my system (EVERYTHING IS AT STOCK SETTINGS RIGHT NOW:)
AMD 1090t
FX-UD3 Gigabyte motherboard
2gb XFX 6870
Corsiar 750W PSU
Anyway, I'm not sure where to go from here. Everything else will kick in gear, but the memory will remain the same speed and it bottlenecks everything. What should I do?
2 answers Last reply
More about memory stuck 667mhz times
  1. DDR = Double Data Rate
    667mhz x 2 = 1334mhz =>1333mhz
    all should be right with your world now.
  2. +1
    or you can say:
    "You can die in peace right now" .... :D
Memory
