Solved
Problem with pci motherboard sabertooth z77 ( first pci )
hello
first pci slot motherboard sabertooth z77 is problem ( if the image does not put the graphic card after 15 minutes ) the other pci are healthy
help mi please ....
3 answers Last reply Best Answer
More about problem motherboard sabertooth
  1. Best answer
    Could you post details of your graphics card as well please.
    And to check, your problem is:
    The graphics card does not provide an image in the first PCI (express?) slot, while it works fine in the other PCI (express?) slots.
    And by "first" you mean the top one
    Correct?
  2. hello
    yes Correct
    after 15 minutes of black screen and must be restart
    test :
    graphic 1 : asus gtx 570 dc2
    garphic 2 : afox 430
    wiht two graphics test
    pics :
    http://i49.tinypic.com/awfigk.jpg
  3. Best answer selected by ata_se7en.
Asus Sabertooth PCI Motherboards
