Okay so long story short my PSU burnt out it was a corsair 800 game edition I just got my replacement and I installed it in my case plugged every thing in took my time booted it up , checked out bios every thing goes great. I save changes and reboot and during the reboot processes the system trys to turn back on but instantly (very fast flash of power light) stops and powers off. So at this point I'm not really sure whats going on so I move to my work bench plug in and hit the power button when I do all the fans spin up for less then 1 second and all the board power leds just give off one very fast blink. Now I have found a strange solution if I hit the power button and then hit and hold reset just as the system flashes on i can make the system stay on while I keep the reset button depressed but even with this solution this does not get me to post the system stays in a pre-post state. Before any one asks I have a PSU tester and all plugs based the test. I have used several power calculators and im 200+ watts over what I need so its not that. I'v checked the power ,reset ,hdd power pins and they are all properly connected iv even tried just using power and reset that doesn't work. All plugs,pins and connectors have been double checked .Ram is properly seated and in the right slots. CPU fan spins up and is completely seated and attached properly. I have built several builds replaced more MB and CPU's then I can handle but in this situation I simply cant figure out the problem.
PS I have tested a spare set of ram and a spare vid card that doesn't need 6 pin power no dice. Unable to test CPU or MB as I don't have another AM3 socket board or cpu
MB: MSI 970A-G45
Ram: Gskill sniper 1600 mhz 1.5v 2x4gb kit
PSU: Corsair 800watt GS *all ready checked to make sure it had the proper rails and voltage*
CPU: AMD Phenom x6 * 2.8mhz *stock
Heat sink: Cooler master 212
Vid: Asus 6870 1gb
HDD:3x 500gb WD Caviar Blue
SDD:1x 60gb Corsair SDD *don't remember model number cant cpuid*
MB: MSI 970A-G45
Vid: Asus 6870 1gb
