I purchased a blue HAF X case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119239
Ive read from multiple sources including cooler masters site that the case uses a 230mm fan in the front, can use 2 200 mm fans on top, and has 1 200mm fan on the side.
I originally purchased 4 or 5 200mm fans for both my computer cases considering i have another HAF X thats not as good but still uses 200mm fans.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835146003
At the time those were my favorite fans, but now i like the couger fans after being told to try them. Sadly i dont think they make 200mm+ sized fans.
The problem with the NZXT fans is that they say 200mm but when i slap them on anywhere on the top or side of my case they dont line up with any of the holes. I also noticed that the holes for all the screws dont line up they are offset for some reason.
Im also trying to figure out how to get the LEDs to turn on and off on my case. I believe i can turn the front fans LED on and off but i can only figure that i would need to hook up all the fans to that front fan. Is that the case? If so i wont be able to use my fan controller installed in my 3.5" drive bay, correct?
Is this problem im having due to the fans, or due to the fact that the fans on this case arent actually 200m?
What fans would you guys recommend i buy? Im looking for something that will push a lot of air but be nice and quite like how the couger fans are designed. I need 2 for the top, 1 for the side, and one of the "230mm" fan for the front. If i could set them up with LEDs that would be great too, im thinking i might just want an LED strip rather than LEDs in the fan.
What do you guys think about all this? Im running a crazy setup and i wanna get into overclocking so i wanna get the best air cooling setup possible. I cant tell what CFM the provided fans have so i dont know if i should just buy another one somewhere for the extra spot that doesnt have one yet, or if i should replace them all with something like the cougar fans that i love so much.
- Thanks
- Thanks
