How to get new motherboard to work in already running PC?
  • Motherboards
a b V Motherboard
November 3, 2012 5:07:08 PM
Had a PC, changed the motherboard, not sure how to get it to work? I have the install disc, but I don't know how to get it to run. The computer starts up, the MSI logo appears, then it goes to the screen asking if I want to start Windows 7 normally (obviously doesn't work), or run repairs (doesn't fix anything).
Pressing the key to get into the BIOS opens up a tonne of options on the command prompt style screen, don't know if they're any good.
What do I do?
Thanks.
More about : motherboard work running
a c 559 V Motherboard
November 3, 2012 5:22:46 PM
Try loading the SATA driver when asked where to install Windows (click load driver) or set SATA to IDE in BIOS and the Windows installation should work without the driver.
a b V Motherboard
November 3, 2012 5:34:09 PM
Do I need to reinstall Windows? I bought the computer as a complete thing rather than building it and purchasing the OS, does this mean I need to buy a Windows 7 install disc?
a b V Motherboard
November 3, 2012 5:38:46 PM
According to the Win7 OEM license yes. The OEM license is valid only for that motherboard.
Have you thought about Windows 8 at all? With Windows 8 you can change motherboards even with an OEM(system builder) license.
a b V Motherboard
November 3, 2012 5:40:37 PM
Nah, Windows 8 doesn't look very appealing for what I want.
Thanks for the answers, suppose I'll have to suck it up and lose everything.
November 3, 2012 5:41:36 PM
Try and see if it does work with SATA set to IDE.
a b V Motherboard
November 3, 2012 5:42:43 PM
Ok. I'm pretty useless so how exactly can I do that?
November 3, 2012 5:49:07 PM
Press Del at startup, enter BIOS, go to the main menu, look for SATA configuration and see what's the setting. If AHCI, set it to IDE. The board's manual should help.
a b V Motherboard
November 3, 2012 6:11:24 PM
I cant see anything like that on the main menu. It says the date and time, then under that SATA Port 1,2,3,4 and wjats in them. I dont see AHCI so IDE anywere?
If I go to boot priorities and set the DVD drive to first, will that make it read the MSI install disc and work?
Thanks for the help.
November 3, 2012 6:13:18 PM
No, what's the board model? I'll look for the manual.
a b V Motherboard
November 3, 2012 6:17:30 PM
MSI H61M-P31 (G3). The manual I got with it is just a stupid little leaflet.
November 3, 2012 6:24:18 PM
You're right. The manual is incomplete. Click the Advanced tab and look for a setting SATA configuration.
a b V Motherboard
November 3, 2012 6:28:54 PM
The advanced tab has-
PCI Subsystem Settings
ACPI Settings
Integrated Peripherals
Integrated Graphics Configuration
Intel Rapid Start Technology
USB Config
Super IO Config
Hardware Monitor
Intel Smart Connect Configuration
Power Management Setup
Wake Up Event Setup
All useless?
November 3, 2012 6:32:10 PM
Look under Intel Rapid Start
a b V Motherboard
November 3, 2012 6:35:03 PM
Rapid start just says Rapid Start is disabled. Just looked in "Integrated Peripherals", it has a SATA Configuration subsection, it says "SATA mode Disabled".
Options are Disabled AHCI and IDE, should I try it with IDE?
November 3, 2012 6:38:08 PM
Yes, try wth IDE.
a b V Motherboard
November 3, 2012 6:39:46 PM
Right thanks.
Was it supposed to have fixed it or is there something else to do? Options remain as repair or start normally, starting normally fails.
November 3, 2012 6:49:31 PM
What about repair?
a b V Motherboard
November 3, 2012 6:50:45 PM
Just tried it, it ends and says Windows cannot solve the problem automatically :(
November 3, 2012 6:54:17 PM
Then you'll have to get a Windows install DVD (7 x64 I'd say).
a b V Motherboard
November 3, 2012 6:55:46 PM
Alright. Would it do anything if I stick the old motherboard back in and run Sysprep?
