What monitor is very Good at 3D vision surround?
  • Graphics Cards
  • Gtx
  • Monitors
  • 3D
  • Graphics
August 9, 2011 3:40:46 PM
A would like to ask for suggestions for a good monitor for 3D vision surround.
im using gtx 560 ti..
More about : monitor good vision surround
a c 217 U Graphics card
a c 135 C Monitor
August 9, 2011 3:47:40 PM
I'm a little confused on which you are looking for.
3D vision - gaming with a 120hz monitor with shutter glasses.
Surround - gaming with 3 monitors, which requires SLI for Nvidia.
3D vision surround combines the two. You'd need a monster setup to handle that.
This is Nvidia's page: http://www.nvidia.com/object/3d-vision-surround-technol...
Do you really want to run 3D vision surround?
August 10, 2011 6:24:22 AM
yup... i just need to know what monitor is good for 3d vision.
August 10, 2011 6:28:37 AM
nothing for your card. Maybe if you SLI a GTX590. Your card is powerful, but you need at least two Nvidia cards to run surround, and with three monitors, your GPU RAM is going to seriously limit your playability. Asus.
a c 135 C Monitor
August 10, 2011 1:43:22 PM
Ok, with 3D vision, which means you are looking at a single monitor that is 120hz with a dual link DVI connection. There is a page on Nvidia's site with a list, but I don't have time to search for it right now. The monitor in my signature is compatible and pretty good. As a side bonus, it also supports AMD's HD3D.
a b U Graphics card
a b C Monitor
August 10, 2011 3:00:39 PM
As joshboy said, it's not possible to run 3 screens with your card, you would need 2 of them.
If you did get 2 and wanted to run 3d surround I would go with 1680x1050 screens like the ViewSonic FuHzion VX2268wm or Samsung SyncMaster 2233RZ, with 3 screens side by side I think the 16x10 aspect ratio would be preferable, and they will be a little less demanding than trying to run 3 1080p screens, also cheaper.
August 11, 2011 3:29:16 PM
thats the answer that im looking for.. lol.. tnx
