Hello, I may be building a new PC for my friend who will be doing gaming but only things like minecraft and garrys mod and older games, he currently uses a laptop with vista and an athlon 64. One of the builds i was thinking of is one made for future upgrades, using a AMD A4-3400 65W, with integrated gpu, (radeon 6410D i think) and then what i need it enoguh power to allow for an eventual upgrade to an A8 quad core Llano and an added radeon 6570 to use in dual mode with it when he either has the money or has the need. what should i get for a wattage power supply? i have never really done much research on the specific usage rates for types of computers so i figured i might as well get second opinions.
heres what i found: a 600W corsair http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
or a 500W OCZ http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
i wanted modular becaus ehe has a case that i will be modding with mounts, fans, and maybe even a plexy window if teh budget calls for it and he wants one so i wanted good airflow and good appearance. but my main consern is which power supply should i use? im not sure whether OCZ oir corsair is higher quality and both are around the same price with rebates and different shipping costs. also i might incluse at least one led cae fan sinc ethey are like 12 bucks for a coolermaster one. i just want to make sure when he needs an upgrade that he doesnt have to replace the power supply as well.
