Closed
Best sound card for about $50-$100
Last response: in Components
Hi :)
There are a LOT of good sound cards rangine from Creative to Turtle beach...
And ranging from $20 to Thousands of dollars....
So you pick whats in your financial range.....probably a Creative one...
Oh and dont forget good speakers, its no good having a $100 sound card and $10 speakers....
All the best Brett :)
Related ressources
on that budget you just want hardware encoding... which offloads the audio from the cpu onto the sound card. sound quality will always be a secondary with such a low end card but thats not to say you can find a good card for the money... stay away from creative budget cards upto the xtremegamer. you may find an asus xonar or a creative fatality second hand if your lucky... but my experience with sound cards is limited.
The HT Omega Striker is a solid card, but I'd recommend the ASUS Xonar D1/DX ahead of it. You also have the ASUS Xonar DS for a bit cheaper, if cost is a major concern.
If your headset has an impedance over 64 Ohms [as many Sennheiser headsets do], then you might consider the ASUS Xonar DG, just for the benefit of its built in amplifier.
Ask the community
