Hey all,
I recently had to replace the motherboard in my HP Pavillion.
The model number for the PC is p6130y
Its a pretty decent machine but I replaced the motherboard with an ASUS M5A88-M.
The issue that I am having is with the connector on the power switch wire. It is not the as the motherboard pins.
The stock HP power connector is 4 pins and one blank. The wires are RED, BLACK, GREEN and WHITE.
I am not sure what the green and white are used for or how to get the switch wire paired to the motherboard.
It appears that ASUS boards use a 2 wire pair for power. I think the same is for reset.
Its been a while since I built a pc, the first and only was in cooled in cooking oil
Other Hardware
AMD Phenom 11 x4 955 Black Edition (also new)
Seagate Barracuda .75 TB
DVD Burner/Lightscribe
No Graphics card, onboard only
300W Power Supply
Any help is appreciated.
revostx11
Other Hardware
300W Power Supply
revostx11
