Re video card //rgb connection// use tv as monitor and broadcast receiver
  • Tuner Cards
  • TV
  • Connection
  • Graphics Cards
  • Monitors
  • Graphics
August 10, 2011 5:46:09 PM
Hello,
The plan is to connect RGB ports between the laptop and the TV. Would a video card allow for the TV to function both as a monitor and the TV, with the usual channels and so on? And then...what video card(s) to choose from?
Thanks...
Bruce
More about : video card rgb connection monitor broadcast receiver
a b U Graphics card
a b C Monitor
August 10, 2011 6:49:14 PM
They aren't building modern graphics cards with built in tuners anymore, you will have to buy a separate tuner card or USB tuner.
I'm not sure I understand the point though, if it is indeed a TV and not a monitor why would you not just use the TV to tune your channels?
m
l
