I just put together a budget build htpc/gaming machine.
What has me stumped, is that the cpu fanis stuck at just below 900rpm.
Fast enough for idle, or barely using the computer, but slower/hotter than what I want for regular use.
When I run stability tester, the cpu comes up to 80 degrees c. Way too hot. All the while, the cpu fan speed stays
at just under 900rpm (at 100% cpu usage)
The computer does stay stable throughout the test, which is nice.
Poking around the bios didn't seem to help.
Googling hasn't turned up anything.
The motherboard is asus m4a785-m (4 pin cpu fan connection, and I'm using a new 4 pin cpu fan)
the cpu: athlon II x3 445 (Unlocked to phenom II x4 b45 no l3 cache)
No overclocking.
ram: ddr2 pc2 6400 2x2gb for 4gb total
PSU: antec earthwatts ea650 green active pfc continuous power
No overclocking.
