Hi, i want to build a computer, so i wanted to first ask the experts on the field, i want a budget computer that i can run good Games,also for simple standar jobs (word processor,internet navigation, etc etc)... i'll also be using Vmware and use multiple virtual machines(i'm a developer) also programs like Oracle,SqlServer,Weblogic etc.
so i choose something simple, my budget it is low for this about $500 and i would like some one to tell me the pros and cons of what i have chosen, for example i'm not sure what type of powersupply will be fine with the following or if all this will fit, so thank you all for the help and this is what i will be looking to buy:
-AMD Phenom II X6 1055T 2.8gHz price $150
-MB Gigabyte
GA-880GA-UD3H or GA-870A-USB3 price $95 and $88
-Sapphire Radeon HD 5770 price $120
-Corsair XMS3 8 GB (2 x 4GB) 1333 price $55
MHz PC3-10666 240-Pin DDR3
Memory Kit CMX8GX3M2A1333C9
please let me know if this is ok and what powersupply you think it will be good, any other suggestion about any part i have listed will be apreciated
-MB Gigabyte
