Sign-in / Sign-up
Laptop problem
  • Chipsets
  • Laptops
  • Heating
  • Toshiba
  • Motherboards
November 6, 2012 8:39:33 AM
Hello,
my laptop keeps on restarting
and over heating TOSHIBA.
More about : laptop problem
a c 1497 V Motherboard
a b D Laptop
November 7, 2012 4:52:40 AM
Hi, If you know how to, it might help cleaning it. If not, take it to a local shop. A cooling pad would help also.
m
l
November 7, 2012 5:21:53 AM
Hello, friend Francis,
Laptop may restart for different reason,
it may cause of over heat also as you mention.
for that you have to minimize the heat by using extra cooler as well you can take some extra technique like during using time you may keep your laptop on a cool surface area. need to work dust free area. you will get some more technique and some maintenance and software solution from bellow site. thanks
http://www.techyv.com/questions/laptop-restarting-itsel...
hope you have got the solution :)
m
l
