Solved
8 pin mobo power connector
Hi,
I have just purchased a gigabyte ga-z77-d3h motherboard. It has a power connectror labeled ATX_12V_2x4 in addition to the 24 pin. My PSU has 8 4 pin connectors. I do not have a 8 pin connector. Can I use 2 4 pin connectors? My PSU is Corsair HX650 V2.
2 answers Last reply Best Answer
More about mobo power connector
  1. Best answer
    Yes you can. The cable with the 4pin+4pin (each say CPU I believe) is for that. They will sorta lock together to make an 8pin and there you go.
    Have fun
  2. Best answer selected by elo_86.
Gigabyte Motherboards Power
