Hello, I am new to this forum and need some help! I have recently built a new computer for multi-tasking with a bit of gaming etc but have run into RAM problems.
The motherboard is a Gigabyte 970A-DS3, and I am using Crucial 8GB DDR3 1600Mhz Ballistix Sport Memory which as far as I can tell is compatible, however the PC seems to be crashing randomly (usually screen freezes then I have to restart/power off pc with the button).
I am sure it is a memory fault because usually after this happens, the pc boots up but only 4GB of RAM is detected in the BIOS check, then it freezes during the windows splash screen and wont boot unless I unplug the PC and leave it for 30mins or so.
I did use @BIOS to update the latest BIOS but no help
System:
Gigabyte 970A-DS3
AMD FX4100
PowerColor HD 7850
Antec 620W PSU
WD 320GB HDD
Thanks Greatly! Matt
System:
Gigabyte 970A-DS3
AMD FX4100
PowerColor HD 7850
Antec 620W PSU
WD 320GB HDD
