I've come to the conclusion after 4 hours, something is either fried or incompatible. Any direction at all would be helpful. I'm going to take it to a repair shop for assistance if this doesn't work out.
PROBLEM: The LED power button flickers and fans move for about a half a second then just shut off. I've made sure the metal risers aren't ground the mobo. I've also tried it with and without the +4 pin connector, originally without.
Here's everything I have with a picture of what it currently looks like.
i3 550 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115065
NVIDIA 460 GTX - http://www.newegg.com/Product/Product.aspx?Item=N82E16814133394
1156 Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157214
Corsair 8GB RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
630W Power Supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
1 TB HD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Card Reader - http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147108
Here's a picture: http://img255.imageshack.us/img255/922/img20111012232210.jpg
I've tried literally everything
