Hi just wanted to know would it be ok to install a 600 watt power supply into a GT5428 Gateway computer?
Dont want my motherboard to blow up. I have a Intel (Coryville) 945G motherboard for the computer if it helps.
You can put 1000W PSU in your computer , the PSU's use the same power output even if is 300W or 1000W. The diference is the 12V power rail ( rails ) for suporting SLI or Crossfire and that's why the wattage is bigger.
