hi all,
recently, my PC just shut down when i'm playing games, so as usual i suspected the fan got clogged with dust,
thus i cleaned my gfx card n make sure no dust etc.
but then after i play games, i noticed the temp rise up to 110++ Celsius quickly
the weird thing is that the fan is spinning strongly (not wobbly), so the fan is still okay i guess
then i touched the heatsink, its not hot at all
but the card is quite hot
so i suspected that the thermal compound not transferring the heat to the heatsink properly
is that right? what else could cause this problem?
as for now im already ordering this thermal compound, is it good enough?
http://www.ipmart.com/my/product/Cooler,Ma...php?prod=315326
oh n FYI, my card is ATI HD 4850 and i've been using it for 4 years now (with frequent gaming)
is it the right time to change the thermal compound?
any help/tips are appreciated
cheers
cheers
