After buying a 560 ti and finding out my CPU was the bottleneck (Yes, my own fault I should have known a 9350e was not going to hold up with modern games) I've decided to to try and build a new computer as cheaply as possible.
At first I was looking a the FX-4100 processor but everyone says stay away, so I've decided to try and go with the Phenom II 970.
ANYWAY back to the point. In my current setup I've been using the Rosewill RP500-2 for several years and it's worked perfectly, but would it hold up in my new system?
The system would be something like:
AMD Phenom II X4 970
8 gigs of DDR3 1333
GTX 560 Ti
One 500 gb sata drive
Standard dvd rw drive
A micro atx motherboard
My apologies if this come across as stupid or desperate because it sort of is. I'm working with vapors pretty much money wise and am thinking of calling the whole build a PC thing off since I'm rather destitute financially as of right now.
If you don't think my current power supply is up to the job feel free to suggest a cheap one that would work. Though understand that sadly, as unrealistic as it is, any PSU above $40-50 dollars at the minute is probably out of my league.
I'm just trying to build a machine to play SWTOR, SC2 and some future games on as cheaply as possible. I wish I could go back and have gotten a cheaper video card if I had known my PC was the bottle neck and have put the funds towards a new PC.
TLDR
Is the Rosewill RP500-2 500W ATX12V v2.01 Power Supply up to powering this system:
8 gigs of DDR3 1333
GTX 560 Ti
8 gigs of DDR3 1333
GTX 560 Ti
TLDR
8 gigs of DDR3 1333
GTX 560 Ti
