Tom's Hardware > Forum > Windows XP > Configuration & Customize > Problem with adding hardware
Forum Windows XP : Configuration & Customize - Problem with adding hardware
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hi!
Can you explain me such problem:
Windows XP work fine, but when I try open "ADD HARDWARE"
service, I receive message, what it is possible to add
only one device at any moment and now adding of hardware
in progress, so stop it before adding new hardware. But
there is no any message about adding hardware. There I can
find info about what is adding and how stop it??
Sponsored Links
On Fri, 30 Jul 2004 00:53:15 -0700, "Anatoly"
<anonymous@discussions.microsoft.com> wrote:
>Hi!
I think the gist of what you're saying is that if you try the Add
Hardware command from Control Panel, you are being told there is
already hardware being added. Could it be that whatever hardware you
have is plug-n-play and that Windows is in the middle of adding it?
Windows XP is notorious for adding detected hardware without your
intervention, even if you don't want it to use its own drivers, or
even to install it at all. Try to wait a while and see if the hardware
eventually gets added on its own (should not take more than about 1-5
minutes). If it does, you can test it and upgrade the drivers if
necessary.
HTH
---Atreju---
Reply to Anonymous
There are 633 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
