Cable for front usb ms-7094
i was gifted a motherboard....ms-7094. is there a cable that i can run from board to front of case to increase number of usbs? Board will support, not sure even what cable is called.i found the pins on the board, but dont have a cable or faceplate or jack for a 3.5 " front old floppy drive space
1 answer Last reply
More about cable front 7094
  1. Front panel card reader/I/O reader. Should connect to the headers on the board just fine.
    Rosewill Card Reader
    Otherwise, there's any multitude of other options you can use to connect those headers for front USB ports. Take a pic. of the connector you found on the board so we can be sure it's not proprietary, likely it is not. This way you can pick up any USB front panel devices and have the functionality you seem to be looking for.
Cable Motherboards USB Components Product
