I am wondering if some other battery can be used to replace the OEM
ones. The replacement battery has to be the same dimensions because the
battery fits in the back between the device and the HDD mount so the
space available for the battery is fixed. I am looking at a replacement
(probably some cell phone battery) because the OEM batteries aren't
locally available in India.
Archived from groups: sci.electronics.components,sci.electronics.design,rec.photo.digital (More info?)
Probably not.This battery looks very long, too long to fit into a cell
phone, and has a cable with a plugh, which was *never* a way to connect
batteries to cell phones.Isn't it possible to order the OEM one for your
device?
Tzortzakakis Dimitrios
major in electrical engineering, freelance electrician
FH von Iraklion-Kreta, freiberuflicher Elektriker
dimtzort AT otenet DOT gr
? "Siddhartha Jain" <losttoy@gmail.com> ?????? ??? ??????
news:1113218681.811768.271480@o13g2000cwo.googlegroups.com...
> Hi,
> I have one of these Vosonic VP300 Mp3-cum-card reader HDD based device.
> It uses a very slim 7.2v Li-Ion battery.
> http://www.pccasegear.com/prod1765.htm >
> Thanks,
> Siddhartha
The battery is specified as two Li+ (actually probably Li-Polymer from
that set of dimensions) 720mAH batteries. They are wired in series
(nominal Li+ terminal voltage is 3.7V).
You might want to use that as a guide to see if anyone carries such a
device near you.
Dear Siddharta,
As Pete already pointed out, these are LiPoly accus.
Since model airplane pilots like these accu cells, it would be
easiest to find a store or online shop which carries this
kind of stuff.
You will get single cells, so you need 2.
These are sometimes labeled as "Kokams". Bring your old pack
to check the dimensions.
HTH
Wolfgang
From-address is Spam trap
Use: wolfgang (dot) mahringer (at) sbg (dot) at
cell
connect
your
> device?
I will have to get them from Australia. One battery costs US$27, which
is ok, but the shipping is $24!! So thats my last option.
> cell
> connect
> your
>>device?
> - Siddhartha
It might reduce your per unit cost if you order more than one, which
probably won't increase the shipping cost.
