Amperage , power and other things...
Power Supplies
Graphics Cards
- Power
Components
- Product
Last response: in Components
Zero Bog
January 14, 2012 7:14:49 PM
- Need Help with case/power supply for streaming/gaming build, among other things - Forum
- Power Supply Amperage - Forum
- Power Supplies, Amperage, Watts, Will this Work? - Forum
- Power Supply Amperage Question - Forum
- Does amperage matter when buying a new power supply? - Forum
Zero Bog
January 14, 2012 8:00:47 PM
Zero Bog
January 14, 2012 8:02:27 PM
Zero Bog
January 14, 2012 8:27:57 PM
Zero Bog
January 14, 2012 8:28:03 PM
Zero Bog
January 14, 2012 8:38:44 PM
Zero Bog
January 14, 2012 9:01:56 PM
Zero Bog
January 14, 2012 9:20:20 PM
I was trying to find a link with the long answer, but can't find it atm... the short answer is that it doesn't really matter. To further complicate the question some multi rail psu's are really single rail systems with individual over voltage protection circuits.
This is a pretty good deal for a decent psu right now.
m
l
Zero Bog said:
Ok,I'll buy an Enermax, but what can you tell me about quad or dual rails system ? How does it work, is better than a single ?http://www.jonnyguru.com/forums/showthread.php?t=3990
m
l
Zero Bog said:
Hi !
I have a PSU with 500W, and 15A on 12V rail ( i know it's small) , but recently i bought a MSI GT 440 video card that need >38A , so i'm liable to bought a new PSU . My question is what you recommend me to buy ? I notice that must have min. 450W .gtx440 itself consumes around 60w only and if you have a 100w cpu then you need around 160w on 12v rail (combined) and thus means you need around minimum 14a rating on 12v rail (combined).
so check combined wattage on 12v rail of psu, if around 200w (aging) or above then you can use that 440 with your current psu (no overclocking)
i think your psu have around 300w capacity on 12v rail, if so then you can try overclocking too, tell us the combined wattage on 12v of your psu
m
l
Zero Bog
January 15, 2012 2:13:20 PM
Zero Bog
January 16, 2012 8:31:31 AM
ko888 said:
For a system using a single GeForce GT 440 graphics card NVIDIA specifies a minimum of a 300 Watt or greater power supply that has a combined +12 Volt continuous current rating of 22 Amps or greater.Yeah , you're right! On video card's box write exactly what you say , + "Minimum system requments based on a INTEl i7 3,2 GHz"
m
l
Zero Bog
January 16, 2012 5:33:45 PM
This one is only a good deal till the 18th...
Then I am sure there will be a different one that is a good deal.
This one is a good deal without rebates and such.
m
l
Zero Bog
January 17, 2012 11:18:17 AM
Actually in the next 48 hours if you are signed up for eblast, this Corsair 600W unit is the better deal
m
l
- Solvedincompatible, better parts for the same price, and other things. help me please Forum
- SolvedCan I use the disc windows 8 comes on for other things? Forum
- SolvedShould i buy a Surge Protector or something to protect my PC from harmful electrical surges and other harmful things? Forum
- Does using an 8-pin CPU power connector on a 4-pin board result in less amperage? Forum
- SolvedOther Things to do When Replacing the Motherboard Forum
- Solvedbuilding my gaming rig and i want to know are this things compatible with each other..? Forum
- Does amperage matter when buying a new power supply? Forum
- SolvedReinstalling Windows on C Drive, so I can move user and other things to my D Drive... help? Forum
- SolvedBuying a New PC Case and Other Things. Need Suggestions Forum
- SolvedIS this a good build with my graphics card and other things? Forum
- SolvedFinal PC Specs (need help with PSU and possibly other things) Forum
- Power Supply Amperage for External USB Disk Drive Forum
- SolvedNeed help with graphic card and a few other things. Forum
- SolvedOne of These Things is Not Like The Other Forum
- SolvedNeed help choosing a cooler/possibly other things Forum
- More resources
Read discussions in other Components categories
