My computer will start up then shut down and start up again after about 2 seconds and it stays on but there is no display from either my GFX card or my integrated graphics, my motherboard's led light indicating there is a problem with the cpu is on. The reason I think the problem is my motherboard is because this happened after I took out all my components and cleaned the case, and I didn't even touch the CPU.
My Cpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073
My Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
My Cpu:
My Mobo:
