Approximate Purchase Date: This week
Budget Range: $1,400.00 - $1600
System Usage from Most to Least Important: Games ,programming, browsing
Parts Not Required: Starting fresh
Preferred Website(s) for Parts: newegg
Country of Origin: USA
Parts Preferences: by brand
Overclocking: I am going to overclock the CPU definitely and maybe the GPU(not decided)
SLI or Crossfire: SLI maybe in 3-4 months(not right now)
Monitor Resolution: 1920x1080 (Still have not decided on one yet)
Additional Comments:
- I Still need to pick out a keyboard(wireless) and mouse(wireless).. any suggestion would be greatly helpful.
I want to keep it @ $50 - $80 for both
- Is any of the components listed below is an overkill or underkill??
- I will be adding more fans, fan controllers, GPU and ssd drive in another 2-3 months but not right now. Is the config as a whole scalable?
Case: Antec Lanboy air Red Black / Red ATX Mid Tower(http://www.newegg.com/Product/Product.aspx?Item=N82E16811129091)
Mobo :Asus P8Z68-V PRO(http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730)
GPU: ASUS ENGTX560 TI DCII TOP/2DI/1GD5 GeForce GTX 560 Ti- (http://www.newegg.com/Product/Product.aspx?Item=N82E16814121425)
Power Supply: COUGAR-SX850 - (http://www.newegg.com/Product/Product.aspx?Item=N82E16817553006)
CPU : Intel Core i5-2500K - (http://www.newegg.com/Product/Product.aspx?Item=N82E168191150720)
RAM : CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 - (http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345)
CPU Cooler: Noctua NH-D14 120mm & 140mm SSO CPU Cooler - (http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018)
HDD: Western Digital Caviar Black WD1002FAEX 7200 RPM SATA 6.0Gb/s - (http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533)
Monitor : ASUS VE258Q Black 25" 2ms HDMI LED Backlight Widescreen LCD Monitor w/Display Port & Speakers 250 cd/m2 50,000,000:1 ASCR -(http://www.newegg.com/Product/Product.aspx?Item=N82E16824236123)
The monitor is something I am considering but not very sure, if you can suggest any other monitors with size >24" and price less that $300.
if anybody sees anything that should be changed, feel free to post. Thanks for the advice
