Closed Solved
Compability issue!! HELP!
Hello Everyone!
I need your advice on which optical drive is better and more compatible with my Antec NSK2480 Case.
Samsung DVD-RW SH-222BB
OR
Liteon IHAS324 DVD-RW
Any Help would be much appreciated!
5 answers Last reply Best Answer
More about compability issue help
  1. Best answer
    DVD drives are... well... DVD drives... They are pretty much all the same if its a decent brand and the right connection.
    Both of those are good. The liteon is deactivated/out of stock on newegg though. I would just buy the cheapest. Although the newegg pic did show the liteon coming with Nero and a SATA cable. so if you want that stuff check when you order it. Some OEM ones have software, some dont
  2. I personally would get this one as it has better reviews and I like Asus. No software though but I use free burning software
    www.newegg.com/Product/Product.aspx?Item=N82E16827135204
  3. dana93 said:
    Hello Everyone!
    OR
    Good question because i know it relates to the depth(length) of the unit.
    Difficult to answer since this info is usually never provided when shopping online.
    I have a couple of older Samsungs a SH-223B & 223C = less then 6" long.
  4. Best answer selected by dana93.
  5. This topic has been closed by Mousemonkey
Antec Optical Media Components
