I've been having some trouble with my PC build and I have narrowed it down to either a bad PSU or a bad/fried MOBO.
My question is:
If my motherboard is dead, will the fan on my power supply still turn?
Summary of Problems
■Nothing seems to turn on or boot when I apply power to the PC
■There are 2 small green LEDs that glow on my video card, even though nothing else works. Would this indicate that the PSU is working?
■No fans turn on. Not the PSU fan or any of the case fans (even the ones that are plugged directly into the PSU and not connected to the MOBO
■The PC booted fine the first time. Everything worked and I powered it down/un-plugged to do cable management. I wore an anti-static band the whole time, which was grounded to the case.
My question is:
Summary of Problems
