Closed Solved
Stuck at no power on a new build
New Build;
ASUS X58 Sabertooth
Corsair TX750
i7-920 microp
12Gigs Kingston mem
Finished the build but no fan on the PSU and the green light on the MBO is on when power is applied. Do I have a bad (brand new) PSU? Confused!
6 answers Last reply Best Answer
More about stuck power build
  1. Best answer
    Hello azdogd1;
    Have you looked over the forum's "System won't boot" checklist yet?
  2. no but I sure will
  3. Had a floppy power connector to the board fan pwr connector, removed it and all works fine. the information you recommended help go back words to start which helped. thanks
  4. Good job troubleshooting your new build.
    Glad to hear it was something easy.
  5. Best answer selected by azdogd1.
  6. This topic has been closed by Mousemonkey
Power Supplies Power New Build Components
