Hey everyone, I've been looking for awhile for a gaming rig that I would be comfortable with for awhile, and I believe I found most of the essentials needed. However, this would be my first rig ever made, and consequently, I have no "know how" on how to check if parts are compatible, or any possible problems i'd have, which I why I came here. If anyone could possibly look over the list for me and let me know what I would need, or any suggestions/opinions you have, that would be amazing. Thank you.
Approximate Purchase Date: End of November 2011.
Budget Range: $1200
System Usage from Most to Least Important: Gaming, Editing (After Effects, Premiere)
Parts Not Required: Mouse, Keyboard, Speakers
Preferred Website(s) for Parts: Links added
Country of Origin: US
Parts Preferences: n/a
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
Additional Comments:
Here's the list:
IN WIN Dragon Slayer Black 0.6mm SECC MicroATX Mini Tower Computer Case
$64.99
OCZ ModXStream Pro 700W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
$89.99
LITE-ON Black SATA DVD-ROM Drive Model iHDS118-04
$17.99
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler
$24.99
[strike]ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$154.99[/strike]
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
$144.99
G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3
$89.99
ARCTIC COOLING Accelero S1 Rev.2 VGA Cooler
$34.99
EVGA 012-P3-1571-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
$319.99
AMD FX-8120 Zambezi 3.1GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8120FRGUBOX
$219.99
SAMSUNG EcoGreen F4 HD204UI 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$89.99
The total comes in at just over $1000.
Budget Range: $1200
Overclocking: Maybe
Here's the list:
$64.99
$89.99
$17.99
$24.99
$154.99[/strike]
$144.99
$89.99
$34.99
$319.99
$219.99
$89.99
